I need wiring help!!!
  • I need wiring help!!!
    Can anyone please help me out with this mess of wiring. I am trying to get my msd box to get spark. I have a msd 6al
    Please help me
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    What exactly is the problem?
      msd does not put out spark
        like this?
          Ok but how do you have it wired now?
            Mine is a Crane Cams unit and it has two wires that go to the magnetic pickup. Came with a little spacer that screws in where the old ICM was and had two little lugs that plug into the magnetic pick up. When I first put it in I had them backwards and it ran like crap. Swapped them around and it has been running great for like 10 years now. You may have to hook up the wire that says "magnetic pick up not used' to one side of the magnetic pick up in the distributor and ground the other? Good luck! Could possibly not be compatible with a festy. Hope it is.
              It's compatible, I run one on my 88.
                i have it like the picture. main red to battery. main black to battery. orange to coil + black to coil -. white to stock coil - red to stock coil +
                what should i change?
                My current plug for the dissy only has 3 wires in it. i guess they could be in wrong. but my ecu is reading the cas
                  I'd love to see a picture, as I suspect that there's an issue with the ICM to 6al wiring.
