I went to put a factory alloy with a new 155 80r tire on yesterday-
got it jacked up and the lugs off-
and the stupid wheel still wont come off-
it looks as if the axle washer in the center, under the friggin nut is larger than the wheel center.
I can't believe this!
So last fall I got a big 25 mm socket - it seems the lip of the axle is bent down to keep it on-
can someone refresh me as to the threads?
are these all right hand thread or are they different on each side? This particular one s the front left- can't see the right as it's parked n the shed, and the back wheel has a cover over the center- hope they aren't all like this.
Who could be so stupid as to put an axle nut over a wheel that might have a flat n the road? And where can I get new washers if it does the same with the alloy wheel? :fofd:
