So i need some pointers on welding my front core support. I have an old Flux core welder.
I will not be getting a different welder! I dont have any friends that can come do the weld for me.
The welder is running pretty good right now. I am going to do a bunch of practice runs with the support metal i cut off and the scraps from my plate. Ill do my best to set up my practice runs to match the conditions in which i will do the welds. My question is about my travel pattern. Im welding 1/4 plate to the sheet metal of the frame area. SHould i do just a v shape travel with like 75% time on the 1/4 plate and 25% on the cars metal?
I will be using a pulling travel style (if theres slag you drag). 10-15° tip angle.
My welder has high and low 1 and 2 (low 1, low 2, high 1, high 2) and wire feed speed dial. Like i said im going to practice on as much material as i cad before i go messing up my car. I might not actually weld the car till the weekend. I really want make it hold and look decent.
Any pointers would help tho. I only had stick welding in school 8 years ago.
