I'm going to be outsourcing most of the welding that's needed on my project because I don't have the equipment or the skills to do it myself. But I'm still going to be buying, measuring, cutting, and sometimes tacking the steel here and there.
My question is about welding steel together that differs so much in thickness.
For example, The lower core support is weak spot and needs replaced. Looks like others have welded a thick 1/4" plate on top of an area that is nothing more than thin sheetmetal (or maybe 2 layers sandwiched).
Can you get good penetration joining such dissimilar size metal?
I know there's a couple of bolts going through the plates, but they are just clamping down to more thin sheet metal.
I was reading in welding forums how hard it is to weld 1/8" thick (.125) plates for roll cages to sheet metal floors.
Yet the plates I see being used here on the core support are twice as thick at 1/4". Idk how you'd keep from blowing out the sheet metal when welding?.
Are the 2 bolts taking up most of load then? And if you ad gussets to the back side, again, aren't you again going to be welding gussets to thin sheet metal that differs greatly in thickness?
I guess I'm just kinda surprised not to find more substantial structure up front (especially when the lower core support is playing multiple duties) in the Festiva.
Thanks for any insight!
