Weighed my BP swapped festiva.
  • Weighed my BP swapped festiva.
    Finally got around to putting the festiva on the corner scales.
    Total weight is 1914 lbs.
    Corners are as follows.
    644. 659.
    305. 306
    For reference, it's a 93 L with a BP with a g series trans, turbocharged with a mitsu 14b and front mount, 1/4 tank of gas, no rear seat, spare tire removed. Full size Battery relocated behind drivers seat,
    I know people are curious about what they weigh after a swap, so here ya go.
    "Its not fast, but its fast for a festiva."
    I'm hoping all of that weight is from the g series and turbo parts lol. I'm swapping a b6d into mine with stock 5 speed. I'm hoping to keep my weight under 1750.
      Larger wheels and tires will add weight too.
      And if you have an Aspire/Rio Swapped Festy, that's going to add weight too.
        It also has aspire front hubs and was on aspire steelies.
          so 68% on front. i think there was a discussion on weight distribution and 70% was good?
            Its FWD...so the more weight you can move to the front axle the better basically.
            91GL BP/F3A with boost
