Does anyone know what size the upper radiator hose is in mm? Just wanting to confirm I thinking if I done it right it's little over 26mm. I talking about inside diameter.
Upper radiator hose.
Last edited by 90fastiva; 10-21-2016, 11:59 AM.1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
Also I would like to know which temp sensor sends to the temp gauge? This is a BP engine to.Last edited by 90fastiva; 10-21-2016, 04:18 PM.1990 Red Festiva STOCK "pregnant roller skate"
Can't tell you for sure- isn't it about 1 1/2 inches or 37mm?
Don't want to ursurp the thread, but I'm also wondering where the fuel pump relay is on a Festy. Firewall in front of the drivers door? Somehow missed it there I guess. Got a bnew relay to try. Gotta get this car back in the shed and all kinds of things to get done.Last edited by harpon; 10-21-2016, 05:56 PM.
I will measure them for you.
Upper and lower rad hose = 1.120" I.D.
exactly the same as the rad necks.Last edited by bravekozak; 10-21-2016, 06:05 PM.
exactly the same as the rad necks.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks.1990 Red Festiva STOCK "pregnant roller skate"
Originally posted by 90fastiva View PostAlso I would like to know which temp sensor sends to the temp gauge? This is a BP engine to.
Pretty much exactly the same as all Mazda B Series engines.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Ok cool deal. Thanks. All my other cars are differnt. So I won't sure which did what.1990 Red Festiva STOCK "pregnant roller skate"
