spark plug broken off in head
  • spark plug broken off in head
    so i bought this festiva that the timing belt was broke. I tore it all down bought a new belt and went to take the spark plug out and it was rounded off and it will not come out for nothing! i chisled all the porclin out of the plug to try and pull it out with a easy out and that wont budge it either i dont want to put much more money into this car since i paid 50 dollars for it and all any ideas? oh and ive heated it up a few times with penatrent oil and let it set.
    welcomsign
    This is a test for patience.
    Keep trying.
    Ask some mechanics what their favorite tool is for getting out a seized plug.
    I hope you don't have to remove the head. But, it may come to that.
    Just be gentle with the head. It's soft aluminum.
      Try an air chisel with a blunt end tool big enough to cover the end of the spark plug base. Turn the power down on the chisel so it does a light tap and hold it on the plug for a few seconds. Use some penetrating oil and your easy out to try to remove it. If it doesn't come out the first time, repeat the operation.
      You gonna race that thing?
        I don't know how well it would work for steel into aluminum but heat then a candle works good for steel/steel.
