Swapped plugs and while I was in there, I decided to pull a compression test... Have been noting a lack of torque across the rpm band and a dip in mpg.
Cyl 1: 155
Cyl 2: 60 (maybe)
Cyl 3: 90
Cyl 4: 90
I was worried about the cam lobes so I pulled the VC and all is good there.
It has a fresh head with valve job and P&P.
Reused the old rings when he was apart as the lands just needed cleaned and the tention was adequate.
But it's the rings...
Now I'm at a crossroads: rebuild the bottom end or swap, and if swap, which swap? I have nearly every B series engine that was brought to the US.
To be honest, I do like the idea of a balls out b3 (which this engine used to be... Could chirp 3rd), but I also wouldn't mind a significant increase in torque, aka BP.
So I ask this, is there a source for NOS rings? If not, then a swap is more likely. Though I think I need to speak with dickmeyer and or dragon healer to see if an improvement can be made with what's there.
Cyl 1: 155
Cyl 2: 60 (maybe)
Cyl 3: 90
Cyl 4: 90
