If you are planning on installing an adjustable fuel pressure regulator, you will need this fuel rail adapter to replace the OEM regulator. Scroll down and notice all the cars it fits, FYI.
Then you can go buy a cheap adjustable regulator like this one.
Here is the Permatex #1 sealant I used on the various threads.
I'll post up a couple of pics tmw of my setup, on my B6 SOHC. This adapter should work for any B-series motor. You might need to re-use the original o-ring or source a new one at McParts. I think that's what I did; it does not seem to come with one. Maybe the o-ring thickness is application-specific?
An adjustable regulator is probably still useful even on an otherwise stock motor, since factories tend to tune slightly lean, for fuel mileage. If you have an AFR (Air/Fuel Ratio) gauge, you can tune for the ideal 14.7 at a steady cruising speed, and get some more power. Stock might be 15.5 or something (higher # = leaner, lower # = richer). No point going lower than 14.7, it's just wasted gas.
Even if you don't have an AFR gauge, you can just bump it up a bit from the stock pressure of (IIRC) 37 psi, to maybe 40, and see if it feels peppier. Then after a while, check the tailpipe for sootiness. If it's too sooty, fuel is wasted, so back the regulator off slightly.
