a/c wiring
  • a/c wiring
    Hey, so I bought an a/c setup from someone. I have never had a good look at a setup installed in the car. I tried to figure out how to connect the wiring harness i got to the various places inside the car when I had my dash out the other week and couldn't find a single connection that matched inside the car. I tried to look up installs on here for photos but there isnt much for pictures of the wiring. So does anyone have photos of what their wiring harness looks like? Im mostly interested in how it hooks up in the car, im sure the plugs in the engine bay are right although now that I think of it i should probably check that too. Anyway, I dont have the gas pedal switch, but the plugs on the a/c switch on your dash and the plugs on the (evaporator?) in the car didnt seem to match anything on my harness. Photos anyone?
    Thanks
    Oh, and the grommets for where the a/c lines run through the firewall- are they different? Or is just cutting holes in the ones my car had fine?
      there is a write up on this if you search for it
      Tommy
      WannaBimmer Build in Progress:
      http://www.fordfestiva.com/forums/sh...-Festiva-Build
        There is a write up on removal and installation. I have read both. However it assumes you removed it and there is no good photos of stuff. I have allthe parts as far as i know but cannot figure out what plugs into the stuff inside the car. Maybe there are 2 wiring harnesses? I wouldnt know. Also with the grommets- i didnt get any so i dont know what their supposed to look like.
          I need to install and get working an a/c setup from an Aspire on the Festiva I need to figure out how to install such system
          Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
          Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
          Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
          it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
          Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
          TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
          bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
          '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
          SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
          R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
          R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
          R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
          R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
          R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
            I have one in my garage that has a/c i am stripping down.I can pull the blower control and send you some pics.I can pull the grommets for you and anything else you need.Pm me with an email or text i can send the pics to.
              Will do, thanks
