info please. was parting out my 92 today and noticed the rear spindles where drilled and had a cotter pin to hold the nut and bearings in place . is this after market stuff or ?? :?
rear spindels
If I remember some had the cotter pin and some of the older one's had the other nut .
Some people that did not have the cotter pins ,drilled theirs and used cotter pins , because they had a hard time finding the crushable nuts .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
No, those are OEM!
IIRC, some were between 91-92 there was a transition to the cotter pin and castellated nut!
You really don't want a crush nut!
How many incidents of a rear wheel falling off have we seen, and I bet none were a properly installed castellated nut and cotter pin setup!
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
I thought of drilling mine when I had them apart to change drums, bearings etc. Sounds like a better idea than the darned "crush" nuts.1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
NO NO NO CAN'T DO THAT !Originally posted by Dave GI wonder how well 2 normal nuts and a lock washer between them would hold up? You know, hold the bearing adjustment nut steady and torque the other nut against it with like a 4' cheater bar?91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
RH and LH ... be careful they're easy to strip out......1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
LH/RH and the right side one is left hand thread
I usualy get away with using them twice before I replace them.~Jeff
2003 Mustang GT 5speed
i never replaced mine, and i had them on and off a buncha times.... they were all bashed up :?
then i got the aspire swap
all aspire's have cotterpins... much better!
~Nate
Current cars:
FOTY 2008 winner!
