So i got my festiva and it has a gas leak and i was wondering the 3 lines lines under the driver door by the back tire. What should i do? Replace the gas line and the tank? You can also smell gas on the inside.
gas leak...
the two pic i posted up is what i could see of the wet spot, ... im thinging about changing the tank and maybe the neck if i can find one or have someone make one..Last edited by Aarawnsenjin; 04-18-2017, 02:57 PM.
Yeah you need to yank that tank and replace the lines. That's a rusty mess.
Double triple check for rust where the rear axle beam mounts. That's what shadetree is asking about.91GL BP/F3A with boost
