I posted this on another site yesterday and no response so far, hence I'm posting it here. It involves an '89 Buick Century with a 2.5 4 cylinder.
Actual question at the end.
WARNING! LENGTHY POST AHEAD!!
Well it happened last weekend.
I drove the Buick to a nearby town, shut off the ignition and it restarted after errands no problem.
Came back into my town and stopped at another store, left engine running and came home to drop things off, left engine running while I brought things into the house in preparation to go to another town.
Got back into the car and put it into 'Drive" and it stalled. First thing I thought was 'Great, the TCC stuck'. Went to restart and all it would do is crank but no start. Tried a few times with same results so I drove one of my other vehicles.(Festiva)
Arrived home a little over an hour later and figured the engine and components had time to cool down and was hoping it was a temperature related problem. Nope, same thing, crank but no start.
Soooo, I started diagnosing and found no spark. Then the rains came and I didn't look at it until today.
Today I reconfirmed no spark and started following the 'flow chart' in my factory service manual and it came down to the ICM. (CPS ohmed out good.)
I called O'Reilly's to see if they had a tester to confirm and took it to them. ICM tested bad and they ordered a new one.
THEN I had them check the new one (because it's located in such a convenient location) and that one failed the test but not near as badly as my original.
They ordered the 2 they could get tomorrow and those will also be tested before the purchase.
BTW these are their 'house brand' Master Pro units.
If both of these fail tomorrow then I'll keep searching for at least a unit that will pass 'out of the box'.
I'm not exactly flush with cash at the present time, otherwise I would simply get a Delco unit from rock auto and be done with it.
Anyone else ever use the 'Master Pro' brand for ignition components and if so, thoughts or experience please.
