I do not know when was the last time I posted anything but I figured I would today after being told that I am under order to finish the car. Now mind you I will admit that the car has been sitting in the garage for the last 6 (yes that is a six) years....and I have been putting things off for a while.... well that ended yesterday. So today I cleaned the engine bay, tried to organize parts (which have been sitting for 6 yrs) and took out the rack n pinion to replace the boots (and to clean behind it). I will start the aspire brake swap tomorrow.....I am on a time limit so things need to get done ........fast......like by the end of the July 4th week. I found an Aspire with only 65k on it so I took the brake booster/proportioning valve, calipers, brakes, rotors, spindles (I think they are the Aspire spindles.....) is there anything that I forgot? I have new bearings and hoses for all for wheels. I do need to get a different brake line to fit the proportioning valve. I am assuming that the rest of the lines I can use.
UNDER ORDERS:
You can use either the Aspire Mc or booster. Mine has both and stops great. I was running only the Mc before swapping for the Aspire booster.
Now both cars are Aspire Mc/booster swapped.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Here's a new order for you: pics! :-)90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by william View Post^ you can also keep the festiva master and booster
I did for years and now run a 99 miata master and booster , love it! It all works just depends on the pedal feel your after.
Takes much less pedal effort to do the same job also when breaking to the limit of the breaks locking you can feel that limit and keep them from locking.
It's hard to explain but after you have them you'll never want to go back.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Originally posted by william View PostTakes much less pedal effort to do the same job also when breaking to the limit of the breaks locking you can feel that limit and keep them from locking.
Might have to do an upgrade this fall.
Thanks
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 06-16-2017, 10:09 PM.
Your welcome there's pictures of the 2 easy mods that need done to the master. Really only one is necessary and thats plugging one port. The other is making the clevis longer to put the pedal back at stock height.
