Just finished a b6t swap in my 93 festiva. Temp doesn't max but definitely gets pretty warm. No signs of head gasket issues. I've seen a lot of guys run the festiva radiator, which is what I'm running now. Any one experience the same issue, upgrade to a upgraded radiator?
B6t swap over heating
How high does the needle get?
What are you using for a fan?
On my festiva the red mark on the instrument cluster gauge is about 240f, 50/50 coolant boils at 265f @15psi, a bit less if your using a 13psi cap.
Do you have the thin manual trans rad or the thicker automatic one?
