Led's and HID's are illegal because they put the beam in a different spot and arent focused properly blinding other drivers. I tried HID's but had to aim them so low to avoid blinding people there was almost no point.
So on your drive do you use mostly high beams or mostly low beams?
If its mostly high beams just get a pair of aux lights and a relay harness for them. John glenn has some very nice ones.
If its mostly low beams then its worth making sure your housings are in good shape, buying new ones if their not. Getting those phillips bulbs i linked. Doing the relay harness. Aiming your lights properly and then seeing what you think.
If thats not enough then look at aux low beams. They are more rare and harder to find but it was what i was going to do.
Also an option is to get the different headlights and grille from the festiva store. They take h4 bulbs and have a much better pattern. But that is $300+ iirc
About 90 percent high beams.....and on Led i was meaning th replacment bulbs ive seen on here on a post...they looked pretty good....adding a couple of driving light would be a decent option also...decisions ..decesions
Uglyed and The Steve
The Steve, 89 L, 93 b3, 81 escort carbed, 5 spd now, metro 13s, 88 323 exh mani, very comfy Suzuki forenza front seats...47 mpg as long as it is above 40°! LOL!
Sweet, mostly high beams is the easy one to fix. The driving lights are the best option. And yes the led replacement bulbs are what were talking about as well. Brighter, Illegal and dangerous. Led or halogen Driving lights are a far, far better option.
Sounds like a good plan to me...now to go light shoppin..thanks y'all
