weber throttle linkage?
  • weber throttle linkage?
    Hey all,
    Got a Weber 32/36 off an old jeep.m used the adapter off the festiva shop. Bolts on good, problem is with the throttle linkage. The old carb linkage that captures the cable is too small to fit on the shaft that goes on the carb and idont have anything else. Is there a kit or something
    Google 32/36 unilink kit you should find plenty of suppliers
      thanks - i'm looking at it but i don't get how it would work..
        I think i'm looking for something like this but i don't know what to search for
          Gold bracket with 6holes goes on carb in place of throttle lever that is on the carb. Silver piece with set screw and two nuts you cut your cable slide it over your cut cable and tighten set screw.Stud and nut go in whichever of the 4 round holes most meets your needs. As in which hole will allow you to pull the throttle wide open from the place where your cable is.Gold bracket with two holes bolts to one carb mounting stud and your return spring attaches to it and your new throttle arm . The silver piece with one hole and a set screw is for a different application.
            Whats wrong with using that one?
              i don't have that one - it's just a photo i found online.
              ricko - gotcha. I think i'm just gonna do that.
                Looks like the linkage on an escort carb .
                  Show a pic of the arm you have.please
                    update - just got the unilink kit and used that - works perfectly thanks
