carb mounting studs
  • carb mounting studs
    Hey out there.
    I need some input from the hive mind.
    Are the studs that mounted the carb to an 88 removable from the intake manifold?
    I have the carb off, and an escort one going on.
    I was going to make my own adapter, but I wasn't able to remove the studs by double nutting.
      Heat the stud with a torch and then try turning.
