It never dawned on me that a water pump (coolant, whatever) could be a serious head trip to even get to. I can see where going in the door I have to remove a lot of things just to get in there, and of course I want to figure out the method of least hassle before I try to make a video out of this: "Marvelous Opportunity to Document Automotive Maintenance"... :angry2:
That having been said, and since it's too late to start on it today, anybody with tips or advice that might go a long way towards preventing my HEAD from exploding - feel free to chime in! Tomorrow it is ON, man. Including a radiator back flush (done out of the car), a block flush, new thermostat, and even a replacement radiator cap so that I know it has the right pressure*
This came to be a definite :naka: "You WILL immediately perform the exercise - move!" (HOO-rah...) kind of a deal when the temp gauge on the dash began to act like an undecided trainee. On startup for instance - the needle swung all the way off the end of the scale, when there was NO WAY the engine had even BEGUN to warm up yet. I got to a gas stop, and sure enough the 'coolant' (utterly rusty nasty water at this point, which I never saw in there before) was barely luke warm...
And yet the day before I had to wonder if the sending unit was even working, since it read nada, zero, nicht, absolutely nothing. "Earth to Car; Whiskey Tango Foxtrot, over?"
So I figure the vanes on the pump impeller finally wore down to a flat disk like they do eventually, and it is time for a total coolant system rejuvenation. Fortunately, I suspected it would come to this months ago because I TRUST NOTHING that the prior owner(s) did to it. I've had all of the parts standing by including a new tube of gasket sealer and a gallon of PURE (not 50/50) antifreeze. But the question NOW is:
How in sweet "F"-all can I get in there to even touch it? It looks like I may even have to dismount the right hand engine mount and lift that end of the mill to gain access!!!
I have an old memory going around the gearbox I call a brain about early Monza cars that you had to pull the engines out of to change the freaking spark plugs on. hmmmmmm
T-Minus eighteen hours and counting people! The machine goes NO WHERE until this is accomplished, so drop a dime while you can.
~ I can also use this opportunity to put the battery on a trickle charger and possibly (possibly...) compare the alternator to some V8 and 2.3 Litre Ford alts that I have laying around. I think a better ALT would be a damn good move
* From prior experience, who wants to bet that once it holds correct pressure I begin to chase leaks all over the place?
