Purchased 3 years ago with 170,000 miles. Would not start. Replaced 3 wires in junction box next to battery, and ran perfectly until now. Car has 186,000 on it now. Problem started about 1 month ago. Had to crank longer to start than normal. Then starting got progressively worse. Longer cranking and starting for short time, and then cut off. Now, today, I tried to start over a three hour period, and fired up for about 3 seconds and cut off. Getting fuel but no fire. I even sprayed fuel in the throttle body and cranked. No fire.
I replaced those three wires again in the junction box, but no help. Sometimes, when I turned the key to crank, the dash lights went blank and engine did not turnover. Battery is fully charged.
I read some posts from other sources that suggested the ECU or the ECU power relay could be the problem.
Any help or suggestions would be greatly appreciated.
