That is a bushing to replace worn out bearings on VW front torsion beam.Any reason someone couldn't produce similiar bushings to rebush a festy rack on the car? Maybe put a slit down 1 side crank the rack all the way right spread the bushing and slide it into the rack turn left repeat. I know nothing about 3d printing so I do not know if this would be a candidate.
Rack bushing idea
Rack bushing idea
That is a bushing to replace worn out bearings on VW front torsion beam.Any reason someone couldn't produce similiar bushings to rebush a festy rack on the car? Maybe put a slit down 1 side crank the rack all the way right spread the bushing and slide it into the rack turn left repeat. I know nothing about 3d printing so I do not know if this would be a candidate.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.Tags: None
