Hi all,
I keep reading things about resetting the ECU by disconnecting the negative battery cable. What exactly is being reset? I know that the ECU has a lookup table for fuel based on the RPM. But does the computer also calculate what the right value is based on sensor input? And then when does it use the calculated versus the stored value?
If I reset my ECU, will the car run poorly for awhile and then get better as time goes on?
Thanks,
Nat
Thanks,
Nat
