temp gauge normal????
  • temp gauge normal????
    Hey guys
    just put a engine in the festiva
    cause the other one kept breaking seals and leaking all over
    never had time to drive mor ethen 20 minutes the other engine.
    whats the normal temperature gauge should be at?
    driving it runs 1/2 and stop lights and drivetrue it ran a little over half
    Fan works cause it came on when I let it idle 20-25 minutes to check the whole engine for leaks.
    Any ways let me know
    thanks
    that sounds about right to me, when it's warmer out the summer mine will run normal a bit over half, ususally where it starts to cover the heat simbol on the gage
      ok thanks man
      cause when i am at a stop light or at a drivetrue
      it goes a bit over half
      just had the car going for about 20 minutes so I am not use to it.
      had one about 6 years ago but dont remember
        Mine sits about 3/4 of the way over on hot! Been there as long as I have owned the car and doesn't overheat!
        93 GL modyfied!!!
        :fish:
          thanks
            temp
            All of mine have run at 1/3 to 1/2 except one that ran at 1/10 ???
              Mine always ran between half-way and two-thirds.
              1988 L - 232K miles Batstiva
              1989 L - 247K miles Slick
                this time of the year mine is always a lil < 1/2... in the summer it goes about right at 1/2, hardly ever above.
                ~Nate
                Current cars:
                FOTY 2008 winner!
                  This is where mine is all the time when driving , on a hot day it might creep just a hair past till the fan brings it down .
                  HD2500 Duramax Chevy
                  Z28 LS1 power 500 +
                    and you have the automatic radiator or an aftermarket one?????
                      mine is like 1/3, so not very warm at all....
                      1992 Festiva
                      2002 Jetta 1.8T
                        That is what John (pu241) and I was wondering , it is a single row rad , but it has a extra switch in the bottom of the rad ,with 2 wires that have been cut and go nowhere .
                        I have good heat , Or I thought I did , maybe I have been cheating myself in the winter on heat . :lol:
                        Z28 LS1 power 500 +
                          does it have 2 tubes in the bottom tank of the radiator that go nowhere? or that have been plugged or crimped off??
                            oh yeah, big difference from the mtx and atx radiators..
                            With the B3, stock mtx radiator, fully warmed up, the needle is just below half during the summer here in Texas..
                            With the stock ATX radiator the needle barely makes it to 1/4..
                              Put in a full width Honda Accord Radiator, two row.
                              Don't need the Fan anymore
