I was in the local Pick-n-Pull today looking for some parts for my Chevy truck and I stumbled across an orange tach cluster. I pulled it and when I installed it in my 88 festiva the tach did not work. Now everything I have read says it should have been a direct swap but upon further investigation I found the the green/yellow wire that is supposed to supply the signal to the cluster was non-existant on both the coil and on the cluster plug. There was not a pin in the plug at all. So after running a new wire from the coil to the cluster everything is kosher. I found one burned out bulb on the right side of the speedo before I buttoned everything up but when I test drove the car I found the needles are not lit up so it is a little hard to read. So i guess i need to pull it back apart and find what else is out. It may have been a headache but it only cost 15 dollars.
My adventures with a tach
My tach was so bright when I put it in , I have to turn the dimmer all the way down . It is so bright , it reflects up to the windshield and makes it hard to see at night.
I need to pull it out and do some modifying , to make it look totally different .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Poverty produces creativity
