Ok. Here's the question. I can get hold of a carbed Festiva. I plan on doing the BPT swap. Will the fact that it was carbed make any difference when it is time to swap the BPT in? Should I look for an FI instead?
the carby fuel pump doesn't support the pressure needed to work with an EFI system. The 2 pumps are not interchangeable, & I think there is a return fuel line.
