This may be a little useful
You are here: Home > Own > Service > Recalls
Recalls
Click here to find out more!
1990 Ford Festiva L Select Different Vehicle
3 Recall Notices
These recall notices may not apply to all vehicles. Please contact your dealer for more details or contact the National Highway Traffic Safety Administration's Auto Safety hotline at 1-888-DASH-2-DOT (1-888-327-4236).
Campaign Number: 96E017000 Date: 1996-Jun-24
Component: Suspension: Front: Control Arm
Defect Summary: EQUIPMENT DESCRIPTION: AFTERMARKET BALL JOINT/CONTROL ARM MANUFACTURED BY MOOG INDUSTRIES. DUE TO MISPACKAGING, CERTAIN BALL JOINT/CONTROL ARM ASSEMBLIES WERE INCORRECTLY PLACED IN THE WRONG BOXES.
Consequence Summary: THESE BALL JOINT/CONTROL ARM ASSEMBLIES WILL NOT FIT INTO THE FRAME RECESS WITHOUT BEING ALTERED. ALSO THE STUD IS UNDERSIZED AND WILL NOT FIT THE SPINDLE PROPERLY POSSIBLY CAUSING A LOSS OF STEERING CONTROL INCREASING THE RISK OF A VEHICLE ACCIDENT.
Corrective Summary: MOOG WILL REPLACE THE INCORRECTLY PACKAGED ASSEMBLIES WITH CORRECT BALL JOINT/CONTROL ARM ASSEMBLIES.
Campaign Number: 95V103011 Date: 1995-Jun-27
Component: Seat Belts: Front: Buckle Assembly
Defect Summary: THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Consequence Summary: THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Corrective Summary: OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES AND CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. THEY SHOULD ENSURE THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUGGING ON THE BELT TO MAKE SURE THAT LATCH IS SECURELY LOCKED, AND THEN PRESSING THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS A SIGN OF BREAKING OR CRACKING OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, OWNERS SHOULD PROMPTLY CONTACT THEIR AUTHORIZED DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Campaign Number: 90V045000 Date: 1990-Mar-08
Component: Seat Belts: Front: Warning Light/devices
Defect Summary: THE "FASTEN SEAT BELTS" WARNING LIGHTS MAY NOT WORK WHEN THE IGNITION IS SWITCHED TO THE "ON" POSITION DURING COLD AMBIENT TEMPERATURES.
Consequence Summary: OCCUPANTS WOULD NOT RECEIVE THIS WARNING TO USE SAFETY BELTS AND CARS WOULD NOT COMPLY WITH FMVSS 208.
Corrective Summary: FORD WILL REPLACE INSTRUMENT CLUSTERS IN THE AFFECTED CARS.
Recalls
3 Recall Notices
