Q: What are the results for frontal crash tests for the Ford Festiva ?
A: Frontal crash tests (29.5 mph barrier) of the Festiva to comply with FMVSS 208:
Date of Test : 06/18/91
Velocity : 29.5 mph
Dummy Type : H2
Head Injury Criteria : 341-Driver, 222-Passenger
(Higher the number, more severe the head trauma- 1000 is considered the maximum allowed)
Chest Deflection : No info
Chest Deceleration : 43 g-Driver, 35 g-Passenger
(Higher G force, the worse for the occupant!)
Driver Femur Force (L and R) : 975lbs-Left,1473lbs-Right
Passenger Femur Force ( L and R ) : 1204 lbs-Left, 1027 lbs- Right
Report Number : HS-629461
I am no expert in interpreting crash data, but I will try and do my best.
First, note that this is related to a frontal head on crash into a fixed barrier. Some degree of safety can be derived from the data, but I stress caution trying to determine a rating for other possible scenarios, such as a roll-over or angled impact. Completely different situation with the likely outcome being much elevated HIC.
Having reviewed many vehicles frontal crash data, I find the Head Injury Criteria (HIC) for the Festiva above to be quite good for a small car. I believe HIC is influenced on the tendency for the occupant's head to strike nearby structure of the vehicles body or components when "rearranged" by the forces of an impact. The Hyundai Scoupe (91) actually failed this criteria miserably (HIC of 1661 and 1604 for driver/passenger). Volvo 240 had HIC of 180 and 198 (a very good rating).
Chest deceleration was to me average across the car lines, I'm not quite clear as to what significance this implies. The Ford Escort for example had rather low deceleration figures, yet still ended up in the top ten highest death rate.
Femur force for the front occupants in the Festiva was fairly good for a small car, though disturbing somewhat is the variation between the left and right. I would suspect this was due to the occupant's legs impacting with some of the interior structure ( steering column, instrument panel, etc ).
One thing I gathered, rear passengers in a Festiva would have it rough!
The Geo Metro rear occupants rear femur forces measured put to be around 235-350. Compare that to the Festiva occupants.
2/02/02
Velocity : 29.5 mph
Dummy Type : H2
2/02/02
