just wondering, since i cant remove the vc for awhile, what do yall think about taking the greased lighting spray it on and scrub it real good with a tooth brush and take a damp rag and wipe off, how well u think this will work? ima try this before long as mines dirty as heck so i figure its worth a shot lol.
grease cleaning,
grease cleaning,
2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
1951 Ford Deluxe, being rebuilt
Have an old car truck or tractor? Go here.
http://www.aintperfect.com/Tags: None
Originally posted by stefanany engine cleaner spray will work wonders if you put some effort into it and scrub everything. Even dishwasher soap and water will clean an engine up decently.2007 Ford Taurus 23-25MPG
The wifes before and after pictures when I put a new valve cover gasket on, I used 10% foamy engine bright and 90% elbow grease.
Yes almost any degreaser will work with a little or a lot of elbow grease ..
HD2500 Duramax Chevy
Z28 LS1 power 500 +
The old stuff works pretty good
But this new stuff works great :!: :lol:
:evil4: :laughing6: :evil4:
Oh yeah , I have seen that------------------------------------------------
Z28 LS1 power 500 +
lol,
anyway ima try to do some cleaning tomm if it gets nice, gonna start on int tho, i know ive asked this before but ill ask again lol
what do yall use for set in stains. ive got coffee (thanks dad lol jk) mud, salt, etc all in my car, im thinking take the resolve stuff and a tooth brush or dish sponge or somthin, let it sit a few, spray with a lil water, then wet/dry vac it up,
think it will work?2007 Ford Taurus 23-25MPG
I will let you know , I just spilled a full cup of Hot chocolate , between the seats Friday morning on the way to work , I could not find the cup , it was dark , then I looked down and it was upside down , on top of the e-brake handle.
Thanks to the McDonalds no leak lid , the cup was empty when I picked it up ??------------------------------------------------
Z28 LS1 power 500 +
well forgot to add this,
yesterday i took the resolve, let it sit a min, then scrubbed it in, then sprayed with water real good, then took the shop vac to it, smells better inside, and the carpet feels softer and looks a heck of a lot better, if i did another cpl of scrubbing (ran out of resolve) would of looked great, some stains still there but not as many, was gonna take pics but forgot lol.2007 Ford Taurus 23-25MPG
Using Resolve to remove stains is a good idea, but...
It leaves a soapy residue if it's not totally rinsed out.
I used to clean carpets and upholstery (for 9 years) and one thing I dreaded to hear was that the customer used Resolve (or one of those other stain zapper solutions). The story was the same every time. "I used resolve and the stain disappeared, but it seems to have come back".
What has happened to these people is that they soaked the stain and then failed to get all of the solution out of their carpet (if they even tried). Every time they walked over that spot, the resolve would clean the bottom of their shoes. The same for upholstery. Put it on a seat and it will clean your butt for you each time you sit. If that stuff gets into the stuffing or carpet pad, it will be there forever, leaking out whenever pressure is applied and continue to clean whatever it touches. The only good part of this is that stains are easy to remove.
These solutions are an absolute bitch to get out of carpets and upholstery. If you have ever used resolve on your carpet, try this. Take a spray bottle of water and a scrub brush, wet the resolve treated spot and start scrubbing. If you failed to remove all of the solution then the scrubbing will create mounds of thick suds. Unless you use some sort of anti-foaming agent, you will be there all day rinsing that stuff out.
A much better solution is the foam cleaners. All the manufacturers make a foam version of their products and it works just as well, but it dries to a powder and can be vacuumed out.
If you have already used one of these solutions, the next time you clean, try the "spray and scrub" trick. If you get any foam, rinse the area thoroughly with warm water and extract it with a good wet-dry vac. You may have to do this multiple times and the suds will clog your equipment. Don't use any soap on these areas.
A warning. Never soak any seat with metal springs. Two bad things can happen. One: The springs can rust and the rust will stain the hell out of your fabric and Two: The corrosion might lead to spring or frame breakage.
One thing to remember when cleaning your carpet or upholstery is that a little soap goes a long way. Using too much may result in a hard to "Resolve" problem.Festiva: Because even my dog can build a Honda.
