I have a 1.3 Ford Aspire, 5-speed manual transmission, 90,000 miles.
At my last oil change, I observed oil in my coolant expansion tank. No coolant appeared in the oil. Since this is the case, I assume that the oil is under pressure where it leaked into the coolant. Having said this, I suspected the head gasket was cracked where the pressurized oil makes its way to the top of the engine. I pulled the head only to find no obvious head gasket cracks or stress. The head and block, where they meet, looked good too.
I am stuck. Should I replace the head gasket not knowing if the head gasket was going bad or replace the head and gasket? I guess another consideration is that the block could have a problem around the oil pump or passage?
One final thing to add. Over the winter, when the car sat for more than 10 hours, one of the hydraulic tappets sounded like it was sticking. After re-starting the engine several times, when this occurred, the tapping would stop. This happened 8-10 times, in total. (Probably not related to the oil in coolant?)
The car ran great , 39 - 44 mpg, and exhibited no symptoms other than oil in the coolant expansion tank.
HEEEEELLLLP. Thank you, Doug
