Does anyone know if the 89 L has the wireing to put a tach dash in? I mean is it plug and play like other years?
89 L model
why?
Believe my tach cluster came out of an 89, but maybe not an L!
But even if I'm wrong, shouldn't be too hard to make a connector and hook it up! got a wiring harness from Kabbage I could hunt down the connector on if I had too!'93 Blue 5spd 230K(down for clutch and overall maintanence)
mine wasn't wired
all years are wired for a tach cluster. both of my '88s have tachs out of other years and work perfectly.Trees aren't kind to me...
well that's odd as i own 2 '88 L models and both are wired to accept a tach clusterTrees aren't kind to me...
My 89l Did NOT have the tach wire (yellow /grn) but it is easy to run and you just modify a female pin socket from radio shack to fit in the connecter.Blue 1989 Festiva L 1.3 carb 160K+, Aspire 5spd, Aspire swap, Tach, Added A/C, Intermittent wipers.
Aqua 1991 Festiva L 1.3 FI 200K+, 5spd, Aspire swap, tach, Intermittent wipers.
Green 1995 Aspire 1.3 FI 95K (RIP Saved my 18yo sons life)
Not the 89L, mine didn't. I put the tach cluster in and it didn't work and I never ran the wire to make it work. I only needed the cluster for the headlight buzzer.Originally posted by FestYboyall years are wired for a tach cluster. both of my '88s have tachs out of other years and work perfectly.
[quote="mattswabb
I only needed the cluster for the headlight buzzer.[/quote]
That's funny because that's the reason I got mine!
Nice to have the tach too, but got it because I kept leaving the lights on in my car during the dark drive into work in the winter!'93 Blue 5spd 230K(down for clutch and overall maintanence)
