ticking from top of engine
  • ticking from top of engine
    welp i did something stupid and put some lucas oil stabilizer in the oil, and started ticking not long after, i drained it out last night and refilled it with pure penzoil, still ticking, im going to remove the vc tomm to inspect it, but what i just got to thinking is that the lucas could be clogging the oil pump? and if it is could i take an air compressor hose wrapped in a rag, and blow that into the vc to try to clear some of the openings out??? would that work at all does anyone know?
    thanks guys
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    1951 Ford Deluxe, being rebuilt
    Have an old car truck or tractor? Go here.
    http://www.aintperfect.com/
    you want to do what, where!?!?!? my friend, you need Marvel Mystery Oil and a little Kero. Run it for a tank of gas and then drain and refill with 5w-30.
      SEAFOAM....in the gas tank and in the oil...will help a lot. In th oil for you Warlocke....will help free up the sticky lifters.
