I just did the head gasket on my '91 Festiva GL auto. I have it back together and the 3rd cylinder is not firing correct. I know this b/c while the engine is running, i pulled the spark plug wires off each individual spark plug and for 1, 2, and 4 the engine idled real rough when i pulled each... for the 3rd though, the engine did not hiccup at all. I replaced all the plug wires, and spark plugs... and there is sufficient spark.. i swapped spark plugs and its not that... oh, btw, the no 3 spark plug is BLACK and 1,2, and 4 are still very WHITE (being new) which makes me think that the injector is stuck open (at least getting fuel)... then i checked that as it was clicking when the engine was running... so the solenoid is going up and down.... then today to make sure it wasn't the injector i swapped no 4 cylinder injector w/ no. 3... still the same symptoms...
so now i think its a valve... i need to check the compression next... if a valve is sticking, what would i need to do? please tell me i don't have to take my head off again. Thanks
