I have a 1988 Ford Festiva L with 117 thousand on her. she will start up, and only stay running if my foot is giving some gas, but once i let off, she dies, but if the car is warm and has been driving, it'll still run at idle, anyone have this problem? any idea's what it could be? help?
She starts, runs, but wont idle
Go to "Profile" above, and give us some idea of where you are.
It also would be a bad idea to read this:
Do the above and I'm sure you receive some possiblities concerning your problem.
Welcome to the festiva family! :wav:'93 Blue 5spd 230K(down for clutch and overall maintanence)
Re: She starts, runs, but wont idle
1988 = carburetor. Sounds like the automatic choke isn't working. Pull off the air filter housing and try spraying some carb cleaner around the carb, Maybe something just got too dirty to work right.Originally posted by peguinsexplodeI have a 1988 Ford Festiva L with 117 thousand on her. she will start up, and only stay running if my foot is giving some gas, but once i let off, she dies, but if the car is warm and has been driving, it'll still run at idle, anyone have this problem? any idea's what it could be? help?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
