Well, I was on my way to work and my by-pass hose came to its end. Now the problem is that noone can get it. I've been to Advance, Autozone, Napa and Ford. Its obsolete. Anyone else have to replace one of these? What did you do? Thanks!
What to do about By-Pass Hose?!
a trip to the JY is in order....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Is this the little hose on the front of the block? Mine blew out and I found a suitable replacement at Advance. It was for something else but I cut it to work.
Sometimes the independant parts houses will take you to the back to check out their molded hoses, match the bends as closely as possible from some part of the length of the hose in stock, mark that part number down, that way you can get the bend again if needed then cut off the excess hose.it runs so sweet
91 L 5spd
PM sentIan
If it is your small bypass hose that comes off the T-stat housing ,
It is no longer available , so you will need this one ..
Gates hose part # 18206 and on the other side of the tag is #0 72053 19142 4
This has the correct bend and you will need to cut a little length off , and it will look like a factory hose .
It will fit right and will not kink .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
