91 L, EFI 5 spd
installed aspire springs, lifted it about 1 1/2 inches.
will too much angle cause a vibration of the trans caused by the halfshaft being at too great an angle? or is the CV joint worn and raising it causing the balls to ride in and out of their comfort zone, or wear pattern.
The hieght shouldn't be enough to afect the length should it.
I think if it would be OK when jacked up with regular springs it should be ok while on the ground with the taller springs?
