I need some help guys. Saturday night i got to my car after it had sat for 8 hours and i started it up and pulled forward a little bit to adjust my headlights on a wall and then turned it off. after i was done adjusting them i went to start, went in reverse for a second and it died. Then i went to start it and all it would do is crank and crank. No starting. After 5 minutes it finally started, but would surge up and down. I kept my foot on the gas a little to keep it from dying. it would go from 2500 to 3500 rpm. it finally ran smooth and i was able to drive it home. It ran fine all sunday. Monday morning was fine, and then i drove to the furniture store after work and then to the gas station, and then it did the same thing again. I couldn't get it started. My brother-in-law came over and I was able to confirm that I had spark when it would not start. It sounded like it was getting a little fuel, because it was making a little noise, but not much. I went to the car this morning and it fired right up. I don't understand this one. Help would be appreciated.
On a side note. The car has had a bad ground at the battery and it wouldn't start sometimes unless i played with the battery cable. Could this be the problem?
