how on earth do you squeeze the two bushings in where the stabilizer bar goes thru the arm? I tried for 2 hours to squeeze it all together and get the washer and nut on, but i cant get it on
Not sure why it wouldn't go?? I just replaced a set a while back, and they went together very easily. Did you try putting a little oil on them? Might help. Did you put new ones on or just putting it back together with old ones? If new, maybe they gave you the wrong part? If you're using old ones, maybe get some new ones.
i got it to go, but just barley. i used two bar clamps. it was really tight for some reason
more problems tho. i whent onto the other side and the bolt where the control arm attaches to the frame is spining. What do i do? do i have to cut the frame rail open??
