When i turn the key on the oil, battery and check engine lights come on and dont disappear. When i start the engine they turn off after a few seconds. Just wondering, is this normal?
Cluster warning lights
Oil will come on cause it sees no oil pressure, Batt will come on cause the alt is not running and that bat is draining, and it senses no rpms so it tells you that something is wrong with the motor . . . all part of the normal self check . . . no if these come on after the engine is running then you have a problem
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
