Where's the blasted horn?
  • Where's the blasted horn?
    We are working on an '88festyL
    Maybe it vibrated off cause of our road...but since I cant hear it, I can'
    t find it! I have 2 more in the backyard, and can't locate the horn on them either. Chilton hasn't helped. I looked in all the obvious places (except one apparently).
    The fuse is good, and the relay is functional, but I can't get a peep from the horn and need help locating it.
    I'm pretty sure the L models had only one horn below the passenger side headlamp. I can't remember if you can get it out by just removing the headlamp and bucket, or if you need to remove the whole bumper cover. Hopefully someone can be more precise - but look there below the pass headlight, anyway.
    jeff
      yes they are behind the bumper, L's are under the the passenger headlight
      and LX/GL have another under the drivers headlight.
      and the only way to get to them is to remove the bumper, sorry
      just be very careful with the side retaining brackets , they love to rust in place.
