NGK V-Powers!
Best Spark Plugs?
v-powers are 2.35 a plug...that's dirt cheap. I'd use champion or autolite in my lawn mower maybe....---------------------------------------------------
I stopped buying spark plugs a long time ago. Aren't modern ones supposed to last the life of the engine? A couple of times a year I take them out and wipe them off and check the gap. Mostly I'm just looking for deposits which might indicate a problem. At the same time I wipe off the ignition wires (for which I do have the ones with the lifetime guarrantee only because I might ruin them while working on the engine), and wipe off the distributor cap. Last time I went overboard and took the ignition coil bracket off the fender and wiped the coil off too. From time to time I hook up a hand held vacuum guage to see if the needle is vibrating indicating a miss and a need for another cleaning. Right now the needle is rock steady.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
^^^^ Yep.. .ditto, except I HAVE worn out modern plugs.. with a LOT of miles..
I usually sand blast mine in my little plug cleaner dealie
Never found any difference between ANY decent plug. High priced metal tipped plugs are a scam, good old Autolites, Champions, Bosch, NGK, all good. Splitfires SUCK...Have had 6 Festys... and counting...
My Website:
http://www.StanfordMotorSports.com
Car Domain:
http://www.cardomain.com/id/Quaddawg
My Garage Page:
http://www.fordfestiva.com/forums/vb...o=view&id=6724
Gimmick plugs are just gimmicks.
I use the autolite coppers. Why? Because they're cheap and I can change my plugs in 10 minutes on this car! Copper performs the best anyways, they just don't last as long.
On my other vehicles I use autolite double plats for longer life.
I've never heard anything good about Bosch +4.www.dantheoilman.com
Go ahead and ask me why
