I just changed my oil and filter, along with the oil pan gasket...After doing all that, I poured a bit of seafoam into the crankcase. Will I need to change the oil again because of that, or will it be fine leaving it?
Seafoaming crankcase
What do the Seafoam directions say?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Normally you're supposed to use these products BEFORE you change your oil and filter, run the engine for several minutes (not driving) and then change the oil...Denis
1993 Ford Festiva XL ~ daily driver, 173000km ~ http://www.cardomain.com/ride/2880751
1991 BMW 318is ~ project car, 178000km ~ page not made yet
