My 89 L 4 speed carb is running better with the new carb. But I still have a slight shudder/jerking when accelerating. Its like you are tapping the gas pedal lightly and rapidly. I am thinking the distributor might be bad, that the advance isn't working right. Any thoughts on this??
Shudder when driving
more likely your off idle compensation tube is clogged (it's in the carb) run some carb cleaner through your bowl.Trees aren't kind to me...
i had an EFI car shudder on me under acceleration and it turns out it was a bad spark plug
may not be your problem, but it's worth a look
