I've noticed a noise only to be described as "through out bearing noise" when the transmission is in neutral and the clutch is out there is a vibration coming from the transmission sounding like a hollow rattle. when the Pedal is depressed just as the clutch starts to disengage the noise goes away. The noise is only present when sitting still and in neutral.
Has anyone else ever ran into this problem? Is it possible to just adjust the free travel to rid this noise, and is it even possible to adjust free travel on Festys?
