Hello, I could use help locating new lash adjusters for my 93 Festiva, or repairing the original. The engine makes a crazy knocking noise at idle and while driving all through the RPM range. Thanks. bugerdup
lash adjusters
The B3 uses hydraulic lash adjuster. They occasionally "tick" if the car has sat for a while (or cold weather) and the oil has leaked out of the HLA. This noise is usually only for a few seconds (Never over a minute) upon starting the engine. I would not expect a "Knock" to be related to the HLA's. Your knock could be something else (bearings or wrist pin). If it is indeed the HLA's (so bad that they don't quiet down), I have never experienced that. I wouldn't even know where to start looking for replacements - except the internet or a Mazda site. The HLA's are locate in the rocker arms at the tip where they press on the valve stem. I would suggest replacing the rocker arm assembly with one from a junkyard - Good Luck
no issues at all, just don't use the aspire rockers.Originally posted by monkeyracingOn a related note, does anyone know of any problems switching from solid to hydraulic lash adjusters in a B6. I've got the "solid lifter" setup now, but would like to go hydraulic for the sake of reduced noise.
JimTrees aren't kind to me...
