Hey guys. I thought I had my timing issues sorted out a few weeks ago, but it seems there are still problems. Initially I had set the timing up wrong, and the car would lack power below 3400rpm, and then take off like a scalded rabbit above that. So, I advanced the heck out of the timing, and it runs a lot better, uses less gas, and I thought all was well.
I've noticed since then that I still have the surge of power at and over 3400rpm, but I also have valve clatter, like the timing is advanced far too much.
Nothing has changed on the engine except for the intake manifold since this problem appeared. I can't see the intake doing this, but who knows?
So, what I'm trying to figure out is if this is distributor related, or maybe ignition module related. I know the cam belt is dead on, so that kind of clears that issue up.
Any thoughts? Oh yeah, 87 block, 88 intake, 89-ish ECU, 93 Festy distributor.
