I have checked the grounds ..good
I have 12.5 volts to the grid .
The grid is grounded to the hatch .
I checked continuity all the way across ..good
I checked each grid individually ..good
I made sure the contacts were clean on both side also ...good
I took my tester and touched both power and ground on both sides of the grid and is is powered , reading 12.5 volts .
The switch lights and the light comes on the dash .
It will not get hot at all ??
I used my laser temp check , it never raised 1 degree ??
