edit: it's an '88 LX - carb 5 speed
I recently purchased a festy awhile back, but didn't get around to registering until recently. I know the seller is responsible for smogging the car before sale, but i figured it was last registered earlier this year so it shouldn't have a problem..
So yeah, it didn't pass smog, actually failed miserably.
It passes all visual and functional inspection except the gas cap is apparently not functioning (?)
The idle is at ~900 rpm , and seems to idle fine but has a super high HC reading. The reading at 2500 pm is a little better but still terrible-- I think they are ~800 and ~560 respectively.. The Gross Polluter limit is 250, and the max to pass is 120.
The CO reading also fails at idle, but actually manages to pass at 2500rpm.
So I'm looking to just get a tune-up and replace the gas cap (hopefully that's all) Anything else I should be looking out for? Common issues? Any help would be appreciated..
Thanks for listening :shock:
