Underneath the Festiva there is a shift linkage that goes into the transmission. It is covered by the black ribbed boot. How do I remove the linkage out of the transmission to replace the seal behind it?
Shift Linkage Removal?
the Haynes manual is nearly useless.... The trans needs to come apart to remove the shift-shaft. It's retained by a rollpin on the inside.Jim DeAngelis
kittens give Morbo gas!!
that linkage has a fork on the other end that moves sliding clutches that engage different gears IE as said it gets pulled into the trans to get it out
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
