LIFTGATE RUST: Rust under bottom of license plate
Paint getting rubbed by the plate primarily is what sets up the rusting process. I've seen this on many Festivas, including the ones I have owned ( used ).Originally posted by BiffMaybe the plate holds moisture in behind and eventually it gets through the paint ??
Once the protection is removed, rust is accelerated by humidity or direct contact with water. When the bottom of the plate is against the liftgate, it allows water to remain in the area of the exposed metal ( the trapping you spoke of ).
Adding rubber pads like I suggested not only keeps the two metal surfaces from contacting each other, it also removes much of the water entrapment.
There are other solutions, but I started with the easiest one.Rich Norman
5 Festivas:
1992 L - Daily Driver
1993 GL-Off-Road Buggy Subaru EJ20DET
1988 L - Big Block Ford Pro-Street
1992 L - Corvette LS7 drivetrain
1991 L - Parts Car
