im installing an msd coil, and i want to get rid of the whole stock coil bracket and just mount the coil on the firewall. am i asking for trouble moving those two modules that are mounted on the bracket? i was just going to attach them to the firewall.
electrical thinggers
do they have a ground wire on them or do they even need to be grounded? if they do need to be grounded scrape some paint off to get a good ground ( just incase ) you dont want arckey sparkey :lol:
Mike, AKA the sasquatch
the only part grounded to the bracket from what I recall is the radio suppression capacitor the square thingy off the coil.
If you want to be sure I usually run a dedicated ground wire with a ring terminal under the terminal I am connecting to the body. kind of a double ground. (sometimes called overkill).it runs so sweet
91 L 5spd
Those aren't thinngers they're do-hickeysOriginally posted by stefanthese two things
Ian
i think alot of ignition componets are made by mitsusbishi. all my friends dirt bikes and mine, my car all have mitsusbishi parts on them
I just looked and my doohickymajigs say "Betty Crocker" and "Just My Size." I think some female may have modded this thing before I got to it!
8)
